93 Cobra OD with tiny hole
sethjon
I just noticed a tiny hole on the starboard side just ahead of where you put the muffs. Its about 1/16 and perfectly round. And of course when you start the engine the water comes out in a stream. Is that normal? If not, can it be plugged with something? Thanks for your help.
cr2k
Re: 93 Cobra OD with tiny hole
It is the weep hole to drain your drive when it is out of the water. Normal, don't plug.
sethjon
I thought so since it was perfectly round. Thanks for allaying any fears.
