jvaccarino
- Joined
- May 2, 2006
- 123
Well, I've got a 93 evinrude..and it's smokin like a sob. Oil and gas mix is automatic... Spark plugs are new, oil line is fine, I unplugged it from the outboard and pumped the ball, oil spills out fine... I guess that just means from the oil tank to the engine, the line is good.. from there?? The spark plugs that were removed did seem to have an unusual amount of oil residue on them.. I had the carbs rebuilt probably a year ago... I've tried carb cleaner, if this helps.. Any input would be helpful. Thanks
Little history about the outboard: Bought used 2 years ago. Boat prior to my purchase sat in a yard, unused for quite some time. I took over, rebuilt carbs, had engine flushed (water was in gas tank).
