Re: 93 johnson lower unit leaking oil
I did not winterize the motor. First winter outside of Louisiana LOL. After I posted this i went out and removed the drain and vent screws for the lower unit oil. Nothing came out. I put my kerosene heater next to the motor to warm it up and after about 15 minutes it started to drain. Unfortunatly the first thing that came out was water
followed by the lower unit oil, then a little more water. I am guessing that the water seperated for the oil as it sitting for a whaile and the water froze forcing the oil upward and out the top port. On a positive note if there is any, I noticed that the vent screw did not have a o-ring on the screw. I am hoping that thats how the water got into the lower unit. I am going to refill the lower unit with new oil tonight.
I didnt have any problems with the moter last year and I fished at least 3 to 4 times a week. I'm hoping after putting the new oil in and adding a gasket to the vent screw will fix her up just fine.
Allthough I didnt "winterize" the motor, I did burn all of the fuel out of the motor so nothing would gum up in the carbs over the winter and greased all of the fittings.
