I just purchased a 1993 Sunbird Regency 195 with a OMC 5.0 HO (Ford) motor with an OMC Cobra outdrive. It has sat in storage for a number of years and I am currently running through the engine to get it back into action for the upcoming season (it is running!!). I am wanting to do a compression check and change the spark plugs on this beast and am having a hard time figuring out how to get to them. The only reachable plugs are #1 and #5. All of the others are obstructed by the exhaust manifolds. Is there a way to change all of the plugs without completely removing the exhaust manifolds and all of the other mechanicals attached to them?? I can't seem to find much info on this process on here or anywhere and the MX manual doesn't provide any guidance. Does anyone have any experience with this or know any tricks?? I have tried using a universal joint and spark plug socket (3/8'') with no luck.
Thank you in advance for any guidance you guys can provide!
