Okay - new season - new thread.
Here's the original thread for reference: http://forums.iboats.com/showthread.php?t=321059&page=4
Picking up where I left off.....
I replaced the PIP inside the distributor hoping that it would be the culprit...
But - It wasn't - Well, not yet anyway because now the engine just dies when I try to increase the throttle any amount past idle.
Note: I took the distributor into my local NAPA store, they ordered and installed the PIP for me. The part was $40.00 and it was ~ $15 in labor because the gear and the collar had to be removed, and the shaft had to be pulled out to replace the part.
Now, I'm back to square one to see why it won't do anything beyond idle.
Gonna check for any new codes....
Do a static ohms test on the new part (compared to the original)
Try to advance the timing a bit more to see if it needs to be more than the 5 degrees suggested int he manual.
Other than that - I'm scratching my head and asking more questions....
Will report back after I get a chance to get back into it...
Dan
Dan
