jvaccarino
- Joined
- May 2, 2006
- 123
Few weeks ago out on the water at full throttle, the engine bogged down to 2500 RPM.. thought perhaps slow mode from overheat/bad sensor.. Sensor seems to be fine, and the engine is not overheating.. I can rev in neutral full throttle, no problem. The problem lies when in gear... Is this an easy fix? I pulled the engine cover off, and I can press the throttle gear forward and the engine passes 2500 RPM.. but seems to be gear linkage or something wrong with the throttle body itself.?? Any suggestions?
