I have a 93 seadoo gtx 587cc with twin black mikuni carbs.
my problem is that the ski will start fine and and run in the water for however long is needed but when I turn it off it will not restart. It cranks but will not start and run. I rebuilt the carbs it still did it and I took off the carbs, cleaned and checked everything was ok. I took it out and it did it again. I also put one of those spark checkers on the plugs while trying to start it and I noticed that when it would first start to crank the light was bright and then would go dim. Could this be the coil/ign module since they are the same unit?
Need help! If there is any more info you need please let me know and I will tell you as much as I can.
