My 150 is on a Stratos bass boat. It is very hard to start when cold (after sitting for a week). I can start at home on muffs with no problems, but drag it to the river and it won't start for love or money. I go thru the sequence...pump bulb, turn key and push in, hold for the 8 count then engage starter. Nothing!<br />Usually, I will wait for an hour and hit the starter and it will fire up. Cold, will have to start 3 or 4 times before it will stay running. I have checked the elect. primer...OK. I have replaced plugs (Champion QL77...the ones the book calls for). After it runs, it will start w/o problems. I have noticed the idle seems high (1500rpm in neutral). Rough idle also. Boat doesn't have many hours on it even being a '93. I bought it 5 yrs ago from older man the scared himself in it. He only used it twice. I haven't put more than 50 hours on it. Oh, I have also removed, cleaned and primed oil tank and lines. Removed fuel filter before VRO pump and cleaned. Pumped out fuel tank and filled with fresh as well as added fuel treatment. Only problem I have found is the roller bushing on the carb linkage was missing. This is the place where the timing advance moves the throttles. I know this is the same old tired repeated problem, but i have read the other post and not really been able to tie "that" situation to the mess I have. Please help!
