I picked up this waverunner which hadn't run about for about 4 years (and was sitting outside).
After a quick inspection, it's amazing how clean and 'preserved' it looked.
It's stock and shows no sign of maintenance (at least all the screws and bolts still have paint).
Here's what I did;
- Fogged the cylinders and carburetor (cranked it a little with the plugs out)
- Drained, cleaned the tank and replaced with fresh/mixed fuel
- Replaced the fuel filter
- Replaced the carburetor diaphragm (because it only cost $4 bucks)
- Replaced the plugs
The results?
- I've got it out of the water on the trailer (with no water hook up)
- Dumped a little gas down the throat and cranked it over.
- I starts right up and sounds good, but after about 5-8 seconds it stalls.
- I repeated this step several times and it stalls as soon as the gas I dump is consumed.
- Fuel is reaching the carburetor via the fuel line (I checked it and cleaned it as well).
- I have not done a compression test (but it sure sounds good for those few seconds of life)
- I played with the carburetor a little (with the jets) but no effect.
Any idea's what could be the problem?
Here's what I did;
The results?
