i'm having a problem with the engine going from idle past 1500 rpms , it will stall when the throttle is pushed forward . it will idle in gear , and if i pull the throttle out to neutrel and rev it up ,then put it in gear before the rpms die down i can get it to go past slow speed all the way to full throttle and run fine .its only at slow speeds from 1100 -1800 or so rpms it will die . so far i have changed the fuel filter /water sep. , drained the carbs to check for water or dirt , and replaced the throttle sensor ,changed the spark plugs ,and checked the wires ,and the compression , all cylinders around 120. any one have this problem before ?
