Re: 93 Yamaha 115 hard to steer
Thanks for all the help and feedback so far guys. I printed the parts breakdown for Bracket 1 from yamaha-motor.com and that helped. The Seloc manual didn't have that particular parts list from what I could tell. I confirmed 5 total grease fittings, and I got them all a few weeks ago. I ended up taking off the steering cable at the motor, and the motor turns real easy, so that sounds like the opposite of MGA's motor. I checked the pull at the steering bracket nut where the cable goes with my cheapie spring-type fish scale and it takes 6 pounds of pull to turn to turn the motor to the left (to turn right) and 4 pounds to turn it to the right. I also greased the pivot tube grease fitting 4 or 5 times and finally a little grease started to seap out of the top bushing, so I feel better about that. I also greased the linkage better at the cable to steering bracket connection.
That said, the steering wheel is pretty tough to turn even without the motor attached. The cable housing isn't in great shape, but it looks all superficial, with no cuts or anything like that to potentially corrode it from the inside out. It almost looks like the rack and pinion at the helm might need to be greased, so that's next on the list. I hear ya on that cable though, MGA, and seems like it's a possibility. I wish I had more experience on this because I don't know what to tell you guys symptoms wise, but maybe I can isolate it enough to the point we can tell what's going on.
I've only had the boat a few months and on the water maybe 5 times and with the turning as it is, I've only ran it about 35 mph myself, but when I bought it the previous owner ran it up to around 50 mph, but I didn't check the tach at that point. I don't really know what the rpms are turning at full throttle. When I had the motor free I also tugged on it and side to side movement is tight and it seems to just engage the steering bracket. When the motor is down on the trim cylinders, I can lift it about 4 or 5 inches up but I'm assuming that's normal in case you hit a log or something. I also took the lower mount cover off the right side and the mounts look good from what I can tell. It had a rubber shock washer under the cover and what looked like 2 rubber washers in front, where the pivot tube is attached to the lower unit area off the motor. Looked like washers and mounts were in good shape. Also, do have a v-style hydrofoil on the motor, and that may be affecting it some. No jack plate, so can't easily raise or lower it. I took a look at a newer Champion boat with and '02 Yamaha 250 on it yesterday with a Sea Star hydraulic steering setup. I wanted to steal that cylinder real bad...
--Steve
