carsonmajure
- Joined
- Nov 27, 2024
- 5
I have a 1995 Mariner/Mercury 15 hp that is having symptoms of a bad prop hub, but I replaced it and it’s still doing it and the hub is in perfect condition.
The motor will work for a little then begin to slip and rev up and lose traction. I can drive slightly above idle but as soon as I give it some throttle it takes off for .00001 seconds then starts revving up but doesn’t move the boat anymore.
The prop shaft splines are in good shape as the propellor itself, the hub is brand new and even after these symptoms still has no damage internally to the plastic/rubber. I have not checked the fluid yet, but I am just curious what the hell could cause this inside the LU? It seems that if it was slipping in and out of gear I would feel the boat jolting/shaking or hear a noise, or if a gear/driveshaft was stripped I wouldn’t be able to move the boat at all, let alone under any load.
