94 150 rude compression readings
crazy charlie
Hi guys can I get some opinions on compression readings on a 94 150hp ocean pro 125on 5 cyls and 110-115 on one.I took the reading on the lower one a few times to be sure.Charlie
ob
Re: 94 150 rude compression readings
While the one cylinder is reading a lower compression,it is still within what is considered acceptible range.Maybe an engine decarb would bring it even closer to the other 5.
crazy charlie
I assume decarbing the one lower reading cyl to start????Charlie
ob
I'd do them all and let the readings fall where they may.I recommend using the OMC engine tuner and injecting it as per instructions into the schrader fitting of the primer solenoid.
crazy charlie
I will have to post back when I have the engine cover off to see where this valve is.Charlie
ob
It's the cap on the primer solenoids red lever.
