Gulfsurfer
- Joined
- May 9, 2006
- 33
When I run over 3200 rpm, overheat horn goes off after approx 5 min run time. Staying at 3200 extends the run time to maybe 10 min, but it still overheats. At first, I would let it cool for 5-10 in then start again and blast off. Then I found that raising the motor and letting the water drain out would quicken the process. maybe I'm draining the hot water out the power head? Anyway...
First off, I have replaced the water pump fairly recently (3 yrs ago), housing impeller, all seals & o-rings. I plan on dropping the lower unit to check the impeller but really expect to find nothing out of the ordinary. I have not pulled the plugs (I will though) or done a compression test to rule out head o-ring leaks.
My direct question is, has anybody seen these symptoms on a 60deg block (150-225hp)? Is there any anomaly with these motor's cooling passages which might cause blockages that are not readily apparent?
Thx in advance for any replies!
