CatTwentyTwo
- Joined
- Jan 11, 2005
- 425
Just out of curiosity, if I remove the brass plugs on the front of the carbs and drain the bowls and then use the primer bulb to refill them, what happens? Will the carbs have a gas/oil mix or will it be straight gas? I'm thinking that it would be straight gas because the oil pump would not be pumping with the motor not running.
