CatTwentyTwo
- Joined
- Jan 11, 2005
- 425
I normally run my engine at 3500 to 4000 RPM and it runs great, but with all the talk recently about what WOT RPM should be, I wanted to see what mine was. From 3500 RPM I went to full throttle and the engine pulled strong up to 4900 and then it stumbled and actually dropped a 100 RPM for a second or two and then it recovered and pulled strong to 5400 RPM. I repeated this three times with the same results. Is there some things I can check, or should I just not worry about it as I don't run in that range anyway?
