Re: 94 200 hp yamaha ran out of oil
Well, it sounds like the motor never really seized up,just got tight and hot, so when your oiling system started pumping it smoked a lot. So I think the worst case could be some scoring or damage to the cylinder walls and pistons. Maybe a bore-scope inspection through each spark plug hole can give you an idea of any damage, without pulling the heads off. In any event better run a 50:1 premix fuel/oil mixture for now, until you establish that your autolube is working. If any damage is minimal then maybe you can continue to run the motor a while, then do compression check in each cylinder. Good luck and let us know what you find!
