Calae 2000
- Joined
- Mar 5, 2016
- 25
Took the boat down to the river Sunday evening. River was high an rough, so I chose to simply back it in the water and start it up on the trailer, with the goal of testing engine performance. I Let the engine warm up, put the motor in gear numerous times just to place it under a load. Ran fine. Only problem I noticed was in looking at the tach the motor was surging from about 600 rpm to 750 rpm. Was would cause the engine to surge up an down at idle ? I did just prior to running the engine clean the 4 barrel quadrajets small fuel filter. I also tried adjusting the idle mixture screws for smoothness. Runs good but not a perfect idle....... Feedback welcomed.
