Re: 94 50hp carb help
I put in new float needle and seat but I still have air flow. 8. take a clean piece of hose, connect to the fuel inlet, with the carb in operating position, blow into the hose, it should blow air out of the carb. now turn the carb upside
down, blow into hose, there should be no air allow thru. this means the float needle is seating, and stopping the flow, as it should.
