94 Bayliner Reflexx Plane Problem???
SRoros
I bought a '94 Bayliner Reflexx last summer with a merc sportjet 90. It takes about 10 seconds to plane out with 2 people in it. If I have 4 people, it could take 30 seconds or more. Once it planes, the top speed is around 30- 35 mph. <br /><br />Does this sound normal, and if not, what could possibly be the problem?<br /><br />Thanks,<br /><br />seth
magster65
Re: 94 Bayliner Reflexx Plane Problem???
Trim it all the way down when you hit the gas then trim it up as you gain speed. Next check your rpm's with what Merc says it's suppose to get. Is the bottom clean? Prop in good shape? Speedo correct?
SRoros
Well its a jet boat, but I never had the impeller checked, which I was thinking could possibly be the problem. I believe the speedo is correct.
SRoros
Oh and the bottom is clean, Its in very good shape for how old it is...looks almost new
magster65
Jet propelled? Disregard my post thanks :) <br />The impeller would be the logical thing to check first. Can you trim the nozzle? If you can the same rules apply. Other than those things there, unless something is binding up, you're going to have to look at the engine. A tune up and compression test is a good start.<br />I think that boat should get on plane faster than it does.
SRoros
Im pretty new to boating... what do you mean by trim the nozzle? <br /><br />Thanks Mag,<br />I appreciate you time
SRoros
Oh, I see the nozzle provides steering... :) <br />I'll have to check the nozzle when I get home
SRoros
No there is no trim tabs. Its a small 14 ft. boat. I guess I'll have to take it in for a tune up
magster65
Sounds like it. The right shop will have some idea of what performance to expect. It also helps to keep all the weight in the boat further forward.
smokechaser068
I have the same boat with the same results. It must be just the boat. Mine just died on the water turns over but doesn't fire changed spark plugs no luck. Help
SpinnerBait_Nut
Welcome to iboats smokechaser. Why not post your question in the mercury/mariner forum?<br />A wealth of knowledge there for sure.<br />Again, welcome aboard.
aturn
All,<br /><br />I have this same boat and I get the same results related to both plane, and top speed. I would assume that this boat simeply tops out at about 35 MPH.<br /><br />My issue is with cold starts. I have a new stater, but cant seem to get it started. It has been sitting for over a year. It's my guess that it is related to the fuel, which I did not add stablizer to before storing in my garage for 12mos +.<br /><br />Question: Is there a way (other than having the fuel pumed) to get my fuel mixture stabilized in order to get the boat started?
SpinnerBait_Nut
Hey AT, welcome to iboats, again, get the engine question to the Merc/Mariner forum for best answers.
