Natedog172
- Joined
- Aug 24, 2011
- 4
I have a 1994 DT-65 on my skiff. At first it was a great motor, but i have owned the boat a month now and there is a problem. At wot or just on plane the motor slows. Almost like a cylinder stops fireing. The problem only presents it self after a 45 minute run early in the morning, and then intermitantly between every 5 and 15 mins in the afternoon. It doesn't die completly. I replaced the fuel pump and the fuel filter and lines..Could a coil be going bad? Also plugs are new...Water pump is great..The primer bulb stays hard during the situation..I have read a lot of other peoples posts on here, but none sounded like my problem. Thanks
