94 Force 120 Tach wire?
SteveinVA
Hi Guys,
Just picked up a 94 Bayliner Rendezvous in need of alot fo work.(mostly cosmetic)
I was hoping someone could tell me if the stock wiring for a 94 Force 120 has connections for a tach? And which kind of Tach I would need.
Thanks
roscoe
Re: 94 Force 120 Tach wire?
could be either purple or grey
It is grey coming out of the regulator, but may switch to purple at the start of the wiring harness.
jerryjerry05
Look up under the dash.There might be a tach connector, taped back, in there.
My dash,it has a bunch of purple wires all suppling power to the components.
They were added,probably cause they had a bunch of purple wire?
The original wire from the motor to the tach(Bhile) purple.
foodfisher
^^^YES^^^^ Mine was folded back and black taped. Only found by laying upside down and backwards and saw the bump in the tape.
SteveinVA
Awesome guys, thanks a ton. This place is the best
jerryjerry05
Just add to the "Send Jerry@ Frank@Food and all the other guys to Australia fund"
