Engine wont start anymore (no spark on all cylinders) and I want to check if it's a kill switch problem. trouble shooting guide tells me to disconnect the black/yellow wire at the pack.
1. Where is it on this engine? Couldnt find it yesterday (i only found the blk/vellow wire going to the switch box)
2.Is it normal that there is liquid (a mix of oil/water..) coming out from the little holes under the lower unit? (see picture). Never saw that before but it's the first time I have troubles with the engine so I was wondering if it's execess stuff coming from the top engine (carbs...) since I was trying to crank it up several times.
Thanks!!
Thanks!!
