MotorheadI000I
- Joined
- May 14, 2008
- 65
Hey guys,
My 94 fling will not run for more than 10 minutes before it stops and will not start again for awhile. I tested the alarms for the overheat to make sure they go off, they do, and checked the timing ect. All of that is fine. Compression is like new. I am unsure what could cause this? Could the CDI be the problem? I have had a similar issue in cars when the ignition control module goes bad. The CDI appears to be pretty new, but the plugs on the coils show it is a little dry, with slight cracks appearing. Any help or suggestions would be appreciated. Thanks
