scatcatttttt
- Joined
- Jun 13, 2007
- 3
Maybe someone can help me out as we are heading out for a weekend of camping and boating this weekend. I had problems this past year with my 112 Johnson (94) not wanting to start. I took it into the shop to have it looked at. They checked the compression....all of which was normal(within 2 of each other), and they rebuilt the carbs. When we land the boat to go out boating, its a royal pain in the A@@ to get started. After that it idles and runs fine.
I had an older johnson (early 80's model), and that was also a pain to get going. Is it just something with Johnsons?
It's frustrating to see people drop their boats in the water and they fire right off and go, yet I have to crank it to get it to fire, then quick put it in fast idol before it dies. (thats the worst part, getting it to fire then not putting it in idle quick enough!)
Any ideas on the problem? Guy that worked on it said that I should disconnect the fuel line from the motor when not in use. Manual also says to try and hold the push choke in for 8 seconds before trying to start it. Also, I try to make sure the bulb is hard before starting it.
I am still pretty much a novice when it comes to working on boat motors, but I am learning, so please try and keep responses easy to understand.
Thanks in advance.
Thanks in advance.
