Had motor rebuilt and broke it in as directed. Motor runs great on plane. Good hole shot and top end. Problem is after it is run for a while. Shut it off 30 minutes to fish then it is hard to start and idles rough when in gear. Idles better in neutral. At the ramp idles rough in gear then dies when I try to drive it onto the trailer. Idle speed in gear is around 650-750 rpm. Wondering if this is too slow. Also wondering if plugs are fuel fouled due to double oil for break in. Thanks.
