Motor will run without problem for 10 Min or so with Temp guage steady just above 150. then all of the sudden it will start to get hot (Towards 240). Throttle back to Idle or just above and it cools back down below 150. Throttle up and it runs at just over 150 for 10 - 15min and again all of the sudden it will start to over heat.
Changed water pump / Thermostat (guy I had do it only showed me 1 thermostat....Isn't there 2??? one on top of each cylinder head?
Being that I live on the gulf coast do I need thermostats?
being that it only overheats when running, let say at 4000rpms for 10-15min, could it be that maybe the VRO pump is not mixing enough oil? and thus causing excessive heat from excessive friction? Checking reserve tank Oil level is getting lower, so maybe just not right muxture at higher RPMs.
Any Ideas would be greatly appreciated.
David.
David.
