sprintracer6
- Joined
- Jun 17, 2006
- 10
I just purchased a 94 VIP Vision 1760 with a 3.0 LX Mercruiser/Alpha 1 Outdrive. When I got the boat home & put the earmuffs on the outdrive with the water hose, I noticed water leaking inside from the engine. Turns out there appears to be a plug of some sort missing from the left rear side of the engine. I'm pretty mechanically inclined, & it would appear that there is a freeze plug completely missing, but when you run your fingers over the opening, it feels as if there are threads there for a plug of some sort. I also noticed the front freeze plug appears to have a bit of a rust line running down the block from it also. Any help with this would be greatly appreciated. I acquired this boat from a deceased father's daughter who had absolutely no idea about the boat other than she claims her father was ridiculously anal about caring for the boat.
