Stromzilla
- Joined
- May 2, 2009
- 47
No spark to the plugs when motor is turned over. Noticed the voltage regulator had some hot-spots so I'm replacing. However, I'm not convinced that module is causing my problem. Also was wondering if there is an ignition cutout when the oil tank gets low enough. My next step is to disconnect the yl/bk wire to the box so I can eliminate the ignition switch from the picture. Can anyone let me know of other possibilities?
