'94 Mercury 25 2stroke WOT adjustment
nw04jen
Can anyone tell me how to get this part to move to 'fully open' when throttle is in WOT - do not know what to alter to make it travel full length - with WOT i am short of max power
nw04jen
I cant post pic at mom until 10 posts - but would say its called throttle cam - its circular with a roller in it - as you puch the throttle lever forward the cam rotates with the roller going backwards - however with the throttle fully forward the roller is not at the extent of the the cam - so if i push the linkage forward in the engine i get another 15mm travel and increased revs (more speed)
nw04jen
do a link and sync
thanks = thats good advice for sure if one knows how to do it!
on another note do you know or have a picture of where the rod interlink attaches under the flywheel at all ? - i can attach easily to the black plastic choke pull part but it came loose under the flywheel and I cannot work how it should seat properly?
many thanks
flyingscott
The L shaped end goes through the hole for the timer base bracket. should be a square hole
