Re: '94 to '97 Starcraft Islander V221 w/4.3LX V-6
Buck n di,<br /> i guess i use your water after your done with it.... i'm Waaaaay Down stream from you.... Northeastern lake Ontario,+ the 1000 Islands, St Lawrence River.....<br /><br />yesterday, i got the carb. tuned in pretty good... Finally cleaned up a bit of a lean stumble in the mid-range rpms... got the right needles,+ jets.. just have to play with the springs a little now....<br /><br />i also turned the pitch screws out a turn or two on the Torque-Shift....in 4"/6" chop i was able to pull an honest 44.9 mphgps(i guess i'll just call that 45 mph), at 4800rpm,+ a bit of trim... when i set the trim, turned on the autopilot, then walked to the left,+ back a bit,, the gps flickered at 46mph....I'M VEERY HAPPY... that's not to bad for full dress,+ 36 gallons of fuel....<br /><br />i'll pull the prop to balance the pitch on all three blades this week sometime... then i'll know where their set( in inches)....<br /><br />it's amazing what another 100hp does for a boat.....<br /><br />well i gotta go...... there's a salmon acallin' my name.......<br /><br />Bondo
