'95 15hp-NO SPARK
clockwork
i have a '95 15hp merc with about 5 hours on it that was running perfect and then just died while trolling. on closer inspection it has no spark from neither cylinders. <br /><br />it is not the shutdown/lanyard switch, it is not the kill switch, and it is not the switch box. i say this becasue i replaced all 3!<br /><br />seeing as it has 2 coils, it cant be those either right? <br /><br />what does that leave? the trigger and stator i guess. which is most likely to blame? <br /><br />the motor is like new and im pissed its already out. the wiring is all good and everything looks perfect. thanks-ryan
andy6374
Re: '95 15hp-NO SPARK
Are your ignition coils grounded? That has tricked me so many times. Could be the ignition coils themselves. But like you said the trigger and stator could be at fault. Check this site for troubleshooting tests on your ignition system.<br />www.biggerhammer.net/mercury/factory_manuals/ <br /><br />Good luck-<br />andy
