Noob Here.
I just got this boat with a cracked lower unit. I ordered the replacement unit and I am working on other things while I wait for it to show. I will post my serial number as soon as I can get it (hopefully tonight). I have the serial to everything BUT the engine.
Anyway, the flame arrestor says Digital Electronic Ignition System on top of it. I wasn't getting fire so I checked the cap and rotor. I found points! Is this normal? That was the last thing I expected to find. The book talks about "Electronic Spark Timing". I cleaned em up and got it cranked. I am very curious about timing now. I think I remember my book saying to set it at 1? advanced. Does that apply to this point setup as well? Should I try to go back to what is supposedly had in it? The engine doesn't die cleanly. It diesels a little bit. So I am guessing fuel loading or timing (or both). Can anyone help shed some light on this subject please? I will have MANY more questions as I go along. I will attempt to ask them in the appropriate section.
I cleaned the carb and would like to know if the book is correct stating to set the idle mixture at about 1 1/4 turns out and the idle speed at about 2 turns out? Sound right?
