mattb100
- Joined
- Feb 12, 2013
- 21
Had some lube come out of the water intakes when i went to fire up for the season. Have unit removed and separated, plan on inspection, cleaning, replacing all seals,gaskets and impeller w/ OEM kits, pressure checking. I have Clymer manual and link to Boatfix Merc manual. Top is in good shape and ready to be put back together. I understand setting the preload and have access to the correct tools. However, checking gear backlash/clearance requires a set of tools I do not have access to. if no brngs,gears,shafts were changed is it necessary to check backlash? When I complete the top I will reseal the bottom, again, same question. Thanks so much for your time. Matt
