95 70hp wiring questions
atengnr
Hi all. Im setting up this new to me motor. Could someone give me a quick overview of the wiring harness wire purposes? Im a decent weekend mechanic but struggle with wiring.
also, how do I tilt the motor without trim functioning? What position should motor be in to check trim oil level?
thanks
jerryjerry05
I believe the unit's down to add oil.
You asked:
There's no way.
It has only one ram and any use lifts it..
UNDER HIGH PRESSURE be careful.
To lift without running the pump, loosen the hyd. stainless line
