I have been in and out of the lower end 3 times in 2 days...functionally, i dont see anything wrong there, impeller looks almost new. Nothing missing as far as i can tell from the evinrude diagrams.
brief history. just replaced powerhead with used one same size. (compression 125-127)
i put the muffs on, supply water, start motor and pee hole shows a good stream of water.
2 min later or less, the console buzzer starts buzzing ...i put hand in the pee-stream and its going between luke warm to ouchie hot and back. (ok...so the thermostat is opening and closing..nothing new there...but is it normal to be so extreme? (and i'm assuming theres a thermostat in there since i didnt open it up to see yet) and also assuming its just not **** poor water pressure or blockage...
turn motor off and steam blew out the pee hole (once)...ok..that has me seriously concerned. the motor never got so hot that i couldnt put my hand on the heads. ok...it was hot, but i could take it.
what is my next step in diagnosis here?
remove/replace the thermostats? I've had several people say just remove the thermostat since I live in Fla, and super cool water will never be a prob.
