95 bass tracker 60 hp
Abel f
my bilge and aireator will not work i am getting fire to connections and if i wire direct they work but not with switch. I have replaced my switch and did not fix the problem
steelespike
Re: 95 bass tracker 60 hp
Your in the prop section you will get more results in electric/electronics.
Did you check the ground side?
Abel f
No sir. I qm new to site. I will try elec. Is there a comon ground on these
steelespike
I don't know that they are but they certainly could be.
