I recently got a 1995 Bayliner Reflex with the Sport Jet 90 engine. It was my stepfathers and he had bought it and was going to fix it, it wasnt running when he bought it. He passed away in Oct and I ended up with the boat.
I have a plenty of experience with engines, having always done my own work on my Audis and I repair medical equipment for a living, so I am very good at troubleshooting and repair. I just need a little advice with this boat.
In looking the boat over, the wiring harness looks like a rats nest. Someone built a new one and its a horrid mess. I have seen pics of other Reflex Sportj jet 90s and they look nothing like the wiring disaster I appear to have here.
So I will need to figure out if the harness was even built correctly. My question about this is can/should I just try to find a used harness somewhere? If so, anyone got some suggestions on where to try?
My other major problem is this one. The boat ended up with snow that turned into water in it over the winter. I covered it after the snow had melted and mostly refroze... the end fact is, it remained filled with water up to the lowest carb throat for about 3 months and I just was able to drain it about a week ago. The air intake was still on the motor and i didnt realize water could seep into the carb throats without being high enough to go in through the air intakes at the top of that cover. I pulled the plugs and turned the motor over by hand. Water shot out of the bottom cylinder. I attempted to get as much water out as possible and put a decent amount of marvel mystery oil in through both the carb and into the cylinder. I dont know how long the water was in the motor. It could have been all 3 months or it could have been much less... I also dont know how much was really in there. I have compression tested all 3 cylinders and all are at about 90 PSI. So, should I just resign myself to fully tearing this motor down and seeing whats going in there or not?
Thanks for the help!
