engine idle speed 2000rpm<br />good spark<br />compression 150,150,130<br />intruduce fuel #1 engine bogs,<br />#2 engine bogs a little<br />#3 engine does not change at all.<br />remove #3 spark plug wire no affect on engine speed<br />I am leaning towards pulling carbs and cleaning, but am unsure of high idle RPM<br />Checked timing, idle timing was 5 degrees before TDC. Adjusted TPI - TPI would only adjust to 5 degrees after TDC. In fact it will only adjust to those two settings either 5 degrees before TDC or 5 degrees after TDC no more no less and nothing in between. So I adjusted to 5 degrees after TDC, rpm's came down to 800, but she started weezing, popping, could this be a lean pop? I introduced fuel thru carbs and she would quit popping. still thinking about cleaning carbs - does TPI need replacing?<br />Thanks<br />Ed
