95 Evinrude 48 SPL/kill switch
Tim.1
I have a T H Marine part # KS-1-DP do I wire it up at the ignition switch to the M (kill switch) and M (ground)or should I run wires thru boat and wire the kill switch red wire to the motor just before the three wire connector that connects the power pack leads to the ignition coils,which would be the black/yellow wire and ground to the motor ground,any advice would be helpfull Thanks:confused:
tashasdaddy
Re: 95 Evinrude 48 SPL/kill switch
correct black/yellow and ground on ignition.
Tim.1
Thanks to everyone for the advice,I got the kill switch wired in,only it`s still too cold for me here in Arkansas,when it warms backup I will let you know how it turned out,hopefully I got it right,Thanks again to all.
