Brock O
- Joined
- Dec 26, 2014
- 60
G,Day Gents...again
Only been 4 years since a full rebuild and yet again it has thrown a ring...Phuk me!!!!
Had no signs leading up to it...was running sweat, after failing to start with what i thought was a dying battery and then a dropped coil...has turned into a nightmare with the worse timing. Didn't experience any cylinder locking as such so wasn't expecting this...compression 120, 110, 110....40. Pulled the side cover to see some top ring but unfortunately not complete.
So I've pulled the power head today and rolled down to the shed, looking for advise on a budget build....yes that's right i want this back together with minimal budget...but still with confidence it will hold up.
Water pump was replaced 6 months ago....water diverter's were replaced with new tell tale location so I'm wondering if its still getting a water block as such cursing hot spots or weather the ring has some how caught the exhaust outlets due to wear ? should the exhaust outlets in the cylinder have been slightly smoothed or radius as such to possible avoid this although that does sound imaginary ? The bottom piston has a small dent also which ill photo tomorrow..same story by the looks.
Any way...I'm only wanting to hone the one cylinder at this stage....replace with new piston and rings....head has a few dents but will clean that up and reuse....potently getting this back on the water for $300 or less as i do have a few spare gaskets from last build. What i can or.....or shouldn't try get away with is the question only good old experience can share..
Any advise appreciated.
https://forums.iboats.com/forum/eng...nson-evinrude-outboards/9145634-0-compression
