95 johnson 28hp
heyttown
I just replaced the water pump kit, and looking to put back together. My long shaft motor has a approx 6" spacer then the leg. When I took them apart it appeared to be factory paint holding it together with no gasket in between. My question is do I put any sealant or sealing compound (gasket maker)on the metal of the spacer and the leg or just bolt it together just as it came apart? My manual doesnt specify anything, so Im guessing no gasket or compound, but want to make sure first.
Thanks
restornator
Re: 95 johnson 28hp
no gasket or sealant is necessary for either side of the extension
