daniel11077
- Joined
- Aug 5, 2005
- 10
the motor died slowing down going across the lake. i changed all the fuel lines and still nothing. i also redid the fuel pump. this is strange how it will start while it is wide open and run but once you start lowering the rpms it dies immediately. it is getting plenty of fuel. you can drain the carbs and fuel drains out of the bowls. when it is running it runs horribly. i know that on a 115 4stroke that under 1500 rpm it only runs on 2 carbs and then above that all 4 open up. i need some help with this one. i have changed all that i can think of. please help if you can.
