95 SEARAY 200 signature speedometer
Cajundave10
I recently purchased the above mentioned boat. Most guages work. This one does not. What type of gauge do these boats use? I do not see a pitot anywhere on the back of the boat.
MPH gauge works off of air pressure from water being forced through a tube
They have a tube which runs from the outdrive to the back of the gauge. Many times all that's wrong is the tiny hole in the front edge of the drive has some junk in it. If you take a small drill bit and put it in the hole on the drive to clean it out, it may just start working again.
