dcmcmullen
- Joined
- Feb 7, 2003
- 2
Bought a 95 SeaRaider F14 with a 120 sportjet the end of last summer. Engine sn#0E100830. The guy I bought if from had only used it about 5 times in over 3 years. He bought it used from a friend of his that never used it. Engine starts up and idles, stalling occationally. Idle seems a little slow and if I let it idle too long the overheat alarm sounds (engine book say's too low idle will cause overheat on the sportjet). The main problem is when excelerating pulling a skiier, sometimes it goes fine but most times its flat(no go just high idle). When this happens there is a strong smell of raw gas and heavy smoke out the back. I took it to a mechanic (tough to find a shop that will work on the sport jet) and they did a tuneup and a service. Spoke directly with the mechanic on the hesitation problem and he said the tuneup should take care of it. He tested it and it runs fine. Before spending a weekend at the lake I tested it in a local canal. It seemed to run fine however I did not test it under load. Got to the lake and sure enough the hesitation was still there. Took it to a mechanic near the lake and he said the 2 top plugs were fouled and replaced all 4 of them, he tested it and said it's fine. Put it back in the lake and the hesitation returned within a 1/4 tank of gas. Now I am trying to troubleshoot it myself. I pulled the plug wires off the bottom 2 cylenders and started the motor. It idles like it usally does. Connected the 2 lower plugs, idles the same. Disconnected the top 2 plugs and the motor won't start. Connected the top 2 plugs started the engine and while idling I pinchedthe fuel line off until the engine started to stall and released it. Hit the gas and it took off fine, backed it down and hit it again and it hesitates again. Pinched the fuel line again, released it, takes off fine. Do I have a problem with the lower carb?? Sorry for the long winded post.<br /> Thanks,<br /> Doug
