OK so what I know so far is when I got the boat the guy I got it from told me the swich was bad. Before I go throwing money in the hole I want to make sure that is the problem. I checked the wires coming out of the swich with a test light and the red wire lights up when touching the frame of the boat so I assume thats the positive. The other two wires are blue and blue with a stripe and neither lights up when touched to a ground. If I touch the light to the red wire and blue wire it lights up and the light goes off when I hit the swich up. The same happens when I use the blue wire with a stripe and push the swich to the down position leading me to beleive the swich is working fine. I went back to the motor and found two wires coming from the tilt motor and I assume power to either wire would make the motor run up or down. I used a peice of wire to connect these wires that go to the trim motor to power and I got nothing. I am guessing that the trim motor is bad but would like someone elses input before spending money on something that may or may not be broke. Thanks any advice is apreciated.
