'95 Yamaha I/O 5.7 overheating
sickofboatsguy
I have a '95 VIP boat with a 5.7 yamaha. boat over heats when running on muffs or in the lake. Boat runs at normal operating temp when bypassing the outdrive and running on a garden hose hooked into one of the cooling lines. There are no blockages in the outdrive or any of the cooling lines. Water pump appears to be working fine with a new impeller. Any suggestions?
Mercnoob
Re: '95 Yamaha I/O 5.7 overheating
did your impeller fail before? You may have debris in the drive or in the hose coming out causing a blockage. you can hook up a vaccume to the hose leading out of the drive and suck any debris out.
sickofboatsguy
Hoses have been flushed and are free of obstructions and the drive was removed, disassembled and re assembled with no obstructions found.
Ayuh,.... How did you determine That,..??
sickofboatsguy
it pumps water. It has to be somewhere between the outdrive and the transom.
