I have a line on a 950 Merc "tower of power" for 200.00. It is attached to a Larson All american (basically a shell) and a small trailer. I'm mainly interested in the outboard but it has not run in I don't don't know how long. It looks like it has seen salt water duty (the lower unit is very pitted along with the prop). I can turn the engine over via the prop though. I also took off the cover to look a little closer and the wiring will definitely need to be replaced....insulation is literally falling off. Is this thing really worth the trouble. How expensive are the lower units to repair....I'm counting on a total rebuild. Does anyone make an electrical harness for these? And probably the biggest question of all, how reliable are they and is there a lot of maintenance (more than other outboards) required.
Thanks
Thanks
