96 115 johnson won't run on low idle
CarlCioffi
I have a 115 johnson that has recently had the carbs rebuilt, new plugs and wires. The fuel pump has been replaced with a pump that has no oiler so the gas has to be mixed. The motor runs fine except if I try to set the proper idle is eventually pukes. I've only been able to run it idling at around 1100 rpms. The rpms go down after a while but then back up however it does not puke on me.
You start with posting a model #----There were 2 totally different 115 HP models in 1996.----Also the trouble shooting on an outboard starts with a compression test.---Post your numbers.
CarlCioffi
It's a J115TLE and the previous owner said the compression numbers were all in the 120 range.
Some will argue.----But you need to start with a compression test today.----And not what the previous owner said.-----And check for strong spark on each lead.----Good spark on that motor will jump a gap of 3/8" or more.-----Testing is the path forward.
CarlCioffi
I will definitely do that as soon as I get my hands on a compression tester. The spark test I can do.
CarlCioffi
so the compression test was 115-120 on all 4 with cold motor. Excellent spark as well. Just a note but I turned the idle down the other day and when I started it this time it was right at 2000. Also I noticed paint on the TDC Mark and from experience I put paint on the mark I'm trying to set it to so it can be seen.
CarlCioffi
So the compression test was 115-120 on all 4 with cold motor. Excellent spark as well. Just a note but I turned the idle down the other day and when I started it this time it was right at 2000. Also I noticed paint on the TDC Mark and from experience I put paint on the mark I'm trying to set it to so it can be seen.
C
Remove formatting
BoldItalicUnderlineStrike-through
Text colorFont familyFont size
Insert linkInsert imageInsert videoSmiliesInsert
AlignmentListInsert table
UndoRedo
DraftsToggle BB code
Write your reply...
Post reply Preview
Attach files
Share:
FacebookTwitterRedditPinterestTumblrWhatsAppEmailLink
FOLLOW US
H
CarlCioffi
I think I just had a brain fart. Could be old age.
Model # is missing the last 2 letters.-----I would check the flywheel key.
J115TLE (DA) is a crossflow motor. when you say turned the idle down... are you doing it properly by disconnecting the throttle cable and using a shop tach with the engine in gear in the water adjusting idle stop screw? if you don't the idle wont respond and/or be all out of wack with the link n synch.
CarlCioffi
I did not but that's a good suggestion. I was only using the tach on the dash out of the water. I will definitely try that hopefully tomorrow. Good suggestion. I will keep you informed. You obviously have more knowledge about outboards than me. I'm very experienced with engines but not so much with outboards.
a rough estimate of rpm out of the water in neutral on the hose is 1000RPM give or take. Some of the older service manuals had a table telling you what the rpm should be on the flushers (no back pressure), in the water (backpressure) and in forward gear idling. the 3 cyl motors were 1100-1200rpm on the hose depending on shaft length. not sure why OMC stopped recommending those figures without backpressure.
CarlCioffi
My plan is to put it in the water today and check the tach. All I have is the dash tach but it will have to be good enough. I did get it in the 1100-1200 range. It runs rough. I am going to contact the seller and ask how long he let it sit in the yard because the last time I had this problem I was guilty of leaving it without starting it up regularly. Won't make that mistake again.
Drain the carburetors or run them empty when you put the boat on the trailer.
The flywheel key puts the flywheel in the correct position on the crankshaft for proper ignition timing.----If it shears the timing will change.-----And no you can not find a sheared key with a timing light.----Well thought out trouble shooting will find what is wrong with your motor !!
CarlCioffi
I didn't realize you were talking about that key. Yes that would be a problem. I would have to investigate that further.
