kept having problems with the motor stalling when shifting from neutral into gear. also at times, would have problems starting. so took her in to get looked at. told me that reed switches were cracked on one of the cylinders. so, they replaced it along with tune up and everything. so the stalling problem seemed to have gone away. yell...that was 2 months ago and i must have put approx. 40hrs on her and i'm seeing similar symptoms. i also went through a box of old parts and supplies i got from the previous owner and found some more broken reed switches that he replaced at some time.
any ideas what might be causing these reed switches to break? is something else possibly causing this? thanks in advance.
